Geopak SS3 Cross Sections - Plot a Tin on existing sections
I am running Geopak SS3. I have created Cross Sections using the "Create Cross Sections" tool under corridor.
The Sections look good.
I created a proposed tin from corridor and I want to check it by plotting the proposed tin as existing ground on the existing cells.
When I plot the proposed tin using the old method, the proposed tin does not plot. I do not know why.
If I use Geopak SS2, the proposed tin plots fine.
Why can't  I do this in SS3?
Thanks for you help,
Phil
