(Posted on behalf of user)
hello,
we used the openroads survey to create a file from ascii data. the file looked good and was as we wanted. we added a google map to the file and it crashed. now when we open, there is nothing displayed. the project explorer shows all the data is still in the file. doing a select all elements shows several thousand elements. if i just draw a line nothing appears. if i open this file first, then create a completely new file, the new file will not display anything i draw. no errors appear in the message center.
thanks
Please post the dataset so we can review. thank you.
Ok, I've attached the dgn file and the xml styles file. Do you need anything else?
Ok, I have the files and am seeing if the DGN can be repaired at all. Not hopeful at this point but will try.
Ok, So I was able to open the file in MicroStation SS3, compress it, and then go back into PowerGEOPAK and see all the data fine. I have attached a copy of the file for your review.
Ok, Thanks Beebe. I tried that with the original file, but was not successful. I ended up making a copy, then removing the survey definitions, compressing and re linkng the survey defs.
