We are using Microstation V8i SS3 and Power InRoads V8i SS3.
We are using Place Plan Note command in Power InRoads and want to make the space between our text and leader a smaller gap. Is it possible to make the gap (see attached image) smaller?
CADTech,
The only way I've found to do so is by using the "Offset" settings under the Text Symbology used for the note. You could also use a Delimiter on your note that would automatically connect to the leader.
Answer Verified By: CADTech1
