I desgned a profile in the roadway designer and have attempted to export the profile to native.
I follow the prompts, and everything appears to work, but when I check the gpk file no proile is found.
I see no error messages.
Thanks for your help.
Philip Mashuda
Philip
in microstation design file settings, under civil formatting, what do you have the option to export to native set to?
NIco,
My file settings are "Use Feature Settings".
Phil
go in your project explorer and find the feature that you are using, right click it and go to properties. under profile make sure the auto export is set to true not false
Nico,
The setting under feature Linear\Road_Centerline , Profile, Auto Export was set to False.
I changed the setting to True.
Exported again, but the corridor profile did not export. Should the name of the profile I used in the corridor appear in the gpk? I renamed the profile in the corridor to PRMPB1 originally was named P_RMPB.
I tried to export a profile in another file and it worked.
I must a have a corrupt file.
I will redesign the alignment in a new file.
Thanks for you help,
Answer Verified By: Philip Mashuda
