I desgned a profile in the roadway designer and have attempted to export the profile to native.
I follow the prompts, and everything appears to work, but when I check the gpk file no proile is found.
I see no error messages.
Thanks for your help.
Philip Mashuda
From my notes for the day I wrote that, I know what project I was working on but I have no distinct memory of the problem I described.
Part of my solution would undoubtedly have been to use the keyin "civil display browser", click the button that analyzes relationships, look for any red entry, and see about either repairing or deleting that relationship. You may have to expand entries in order to find the red entries. If I had to guess, I might have solved it by changing the profile's or alignment's name, because I know that Geopak has constraints on the naming of some elements. I may have had to delete the profile and start over. I may even have had to start a new file, import all my other alignments from Geopak's database and then reconstruct the offending profile. I hope that helps; I wish I could remember what I did to solve this problem.
