InRoads Ss2 - Report Browser Error - Failed to Load File
I have a user on XP who has used the report browser in the past, but today, it generates and error dialog box stating Failed to load file ... and if you browse to his TMP folder, the file is there but the InRoadReport.txt and the corresponding tmp files are also there, but are zero bytes.
I even had him open the rawxml.xsl report and save the XML file to his desktop and then try opening it in the report browser. Same basic error message.
We all use the same project defaults that are driven by CFG files so our reports are on the network and I seem to have not problems.
Does anyone know why this type of error occurs and how to correct it.
Even a reboot of the PC did not help.
