MX V8i Longsections
I'm creating numerous project control line longsections through input files with standard LONGDRAW and LONGLINE macros.
In these longsections I'm displaying the horizontal and verical geometry information by referencing the proposed control line "G" string.
This annotates the longsection display with R for horizontal radius, D for horiz straights and CL for transitions and K for vertical radius and P for gradient etc.
Is there a way to amend/alter these annotation letters in MX? For example, the transition CL to become TL, the horiz D to be L and the vertical gradient P to be G.
I can manually change each section once they've been cut and output using either Microstation or CAD but it's very time consuming.
I've looked at the LONGDRAW and LONGLINE macros and can't see any way of changing these values.
Any help gratefully received.
Cheers,
Gary
  • Hi Gary
    The geometric annotation is being carried out to a set schematic style in the macro, the annotation labels are fixed for the schematic style.
    If you want to have control over the annotation labels the best approach would be to create an input file for the long section and control the annotation using linemode. The example below show the linemode for the horizontal and vertical schematics. The 001 code can be changed to suit what you require.
    001,Gradient =&GRTV&% can be changed to 001,G=&GRTV&%
    HORIZONTAL SCHEMATIC
       Define annotation area
    845,bbl,,3=box2,9=-6.0,3.0
    808,4=0.1
    701,gast,,box2
       Draw Horizontal Schematic line
    711,gast,,hlin
       Annotate Straights with infinity symbol
    721,gast,line,10=90
    721,3=tval,4=-48
    001,R=&tval&
       Annotate transition A value
    721,gast,line,10=90
    721,3=tva2,4=-42
    001,A=&tva2&
       Annotate radius of curves
    721,gast,line,i000,10=90
    721,3=tva3,4=-44
    001,R=&tva3&
       Annotate length of curves
    721,gast,line,i001,10=90
    721,3=tva4,4=-45
    001,LC=&tva4&
    VERTICAL SCHEMATIC
       Set up box and text box width 3.0 cms
    810
    805
    845,BBL ,BCPT,1009,9=-6.500,3.0
    845,BBL ,CL ,3009,6=-6.000,6,,-13.500,3.0
    808,4=0.4,,0.75
    806
    847,*,,3009,10=0
    001,VERTICAL
    808
       Specify Reference String for Vertical Schematic diagram
    701,GAST,,1009
       Set up line colour and style for Vertical schematic VLIN line and draw it
    805
    806
    810
    805
    711,,,VLIN,0.2
       Set up text colour and style
    806
    808
    806
    808,4=0.18
       Annotate Radius value
    721,GAST,10=90
    721,,,VRTV,-44
    001,Radius =&VRTV&m
       Annotate Radius length
    721,GAST,I001,10=90
    721,,,LRTV,-45
    001,Length =&LRTV&m
       Annotate Gradient length
    721,GAST,10=90
    721,,,GLTV,-40
    001Length =&GLTV&m
       Annotate Gradient
    721,GAST,,I001,10=90
    721,,,GRTV,-23
    The dimension annotations for option 721 are listed below
    -23.0 Percentage gradient
    -40.0 Length of straights
    -42.0 RL/A value of transitions
    -43.0 Length of transitions
    -44.0 Radius of curves
    -45.0 Length of curves
    -48.0 Radius of straight
    -53.0 Vertical radius (G strings)
    Answer Verified By: Gary Manship
Reply
  • Hi Gary
    808,4=0.1
    701,gast,,box2
    711,gast,,hlin
    721,gast,line,10=90
    721,3=tval,4=-48
    001,R=&tval&
    721,gast,line,10=90
    721,3=tva2,4=-42
    001,A=&tva2&
    721,3=tva3,4=-44
    001,R=&tva3&
    721,3=tva4,4=-45
    001,LC=&tva4&
    VERTICAL SCHEMATIC
    810
    805
    808,4=0.4,,0.75
    806
    847,*,,3009,10=0
    001,VERTICAL
    808
    701,GAST,,1009
    805
    806
    810
    805
    711,,,VLIN,0.2
    806
    808
    806
    808,4=0.18
    721,GAST,10=90
    721,,,VRTV,-44
    001,Radius =&VRTV&m
    721,GAST,I001,10=90
    721,,,LRTV,-45
    001,Length =&LRTV&m
    721,GAST,10=90
    721,,,GLTV,-40
    001Length =&GLTV&m
       Annotate Gradient
    721,,,GRTV,-23
