MicroStation SS3 08.11.09.459
GeoPak SS2 08.11.07.615
ProjectWise SS4 08.11.11.111
Windows 7 Enterprise
Trying to use the corridor modeler cross section labeling tool and every time I click on itI get an error that states: “Job number can not be found in the active directory". This project is in ProjectWise all other tools are working OK.
I have also tried this outside PW as well as on other similar PCs. The GPK file in the same directory as the CAD file with the rddbs folder in that same directory.
this issue could also be that you have a corrupted chain in the gpk. try and rebuild database.
From my experience, the xs labeler tool does not like it when the GPK directory is set using a variable, such as _GPK_DATA mentioned above. Set the GPK directory to an actual folder path and the labeler should work.
GEOPAK SS2 08.11.07.619
ProjectWise Explorer SS4 08.11.11.574
Has anyone been able to resolve this? I am seeing this issue on all ProjectWise projects, even if I remove ALL Config Blocks and the paths are correct. The GPK file is not corrupt as this is happening on everything. It does work if the GPK is moved outside of PW and change the path in the prj while actively working in a PW dgn file. This has to be a bug if it does not work out of the box with no variables. I think I can partially speak for everyone up the thread here that this workflow must stay inside of PW, not a good idea to move things outside.
Mark, there could have been an issue with that build you have. that is a priority build and there is a newer one. I will send you a link via private message, you can try it and see.
I am sorry for the inconvenience with this. I have tested it and can confirm the behavior. I have filed a defect
D-133194
Corridor Modeler > Cross Section Labeling does not open with cogo in PW
Answer Verified By: Nico Roman
