MicroStation SS3 08.11.09.459
GeoPak SS2 08.11.07.615
ProjectWise SS4 08.11.11.111
Windows 7 Enterprise
Trying to use the corridor modeler cross section labeling tool and every time I click on itI get an error that states: “Job number can not be found in the active directory". This project is in ProjectWise all other tools are working OK.
I have also tried this outside PW as well as on other similar PCs. The GPK file in the same directory as the CAD file with the rddbs folder in that same directory.
We are also having the same problem with labeler when working with ProjectWise
MicroStation SS3 08.11.09.357
GEOPAK SS2 08.11.07.619
ProjectWise Explorer SS4 08.11.11.567
Windows 7 Professional
According to the Greenbook the GPK Directory should be defined as _GPK_DATA.
Is this used in "GetJobNumbersWithinActiveDir"?
which greenbook are you referring to?
make sure in your geopak preferences, cogo preferences, job directory that you set the path by selecting with the hour glass.. i have seen it where if you don't have the \ at the end of the path
I am experiencing the same issue. I have checked the Job Directory, and the Corridor Modeler is using that gpk for creating the model. It appears that the error checking within XS Labeler is not working correctly. Also, in the suggested answer it says that there should be not "\" at the end of the job directory, but when you select it withe spy glass, that is what you get.
