MicroStation SS3 08.11.09.459
GeoPak SS2 08.11.07.615
ProjectWise SS4 08.11.11.111
Windows 7 Enterprise
Trying to use the corridor modeler cross section labeling tool and every time I click on itI get an error that states: “Job number can not be found in the active directory". This project is in ProjectWise all other tools are working OK.
I have also tried this outside PW as well as on other similar PCs. The GPK file in the same directory as the CAD file with the rddbs folder in that same directory.
I have found that it we could get it to work only if we used the Project Manager. If we opened project manager, then cross section labeling and earthwork would work. If we tried accessing either one of those modules while in ProjectWise, neither would work.
Are those modules written to get the directory from Project Manager?
yes, project manager sets the directories for you. the pw problem has been filed as a defect
communities.bentley.com/.../177385.aspx
With some experimenting I seem to have come up with an answer. the source of the error is if the GPK was moved or renamed. Starting with a clean GPK and importing the chains it seems to be working. If the file gets renamed or moved the error returns.
I worked with FDOT CADD Support (ECSO) on this one and they found a solution (atleast for my issue). I had Rdxsrd_shg selected as the Model and I received the exact same error message "Job number cannot be found in the active directory", when attempting to launch "Cross Section Labeling" . I changed the Model to "Rdxsrd" and also confirmed that I had a "\" backslash after the path in my working project directory and in my COGO Preferences Directory Paths. These steps resolved the issue for me. I am using PowerGEOPAK SS2 08.11.07.615. I am not using ProjectWise or SS3.
