Hello there!I have this issue, when i was done creating a surface (dtm) using Inroads, i wanted to view the low/high points of that surface, so is there any way to view them using InRoads???Thanks & Regards,Imad Balich
Two workflows come to mind:
Thanks Jacqueln for your reply...
i actually wanted to view the lowest and highest points on that surface....
Use hydraulic and hydrology application add-in. There is a tool you are looking for.
Adam, do you mean the Display Peaks and Pits command? The Display Peaks and Pits command displays points on a DTM surface where all adjacent triangles slope away from a point (peak) or slope toward a point (pit). The points are drawn with zero-length lines.
So, it will return all peaks, not just the highest peak.
