An issue came in today that I think will benefit the community to see troubleshooting techniques as we work toward a resolution.
Version 08.11.07.427
I am using corridor modeling, and would like to use the cross section labeler. I can get it to run, but the slope comes out as a percent instead of ration, and elevation is 4 decimal places. Can you help me get my settings updated to get these two items to run better?
You may not see the other options due to the version you are running. But in the Cross Section labeler in the Corridor Modeler interface you should be able to see seven different format options under tthe symbology settings. The Ratio option is there and you can also control the number of decimal places there. If you do not see those options then you can uninstall your version of GEOPAK and install the latest version 08.11.07.615.
