I am having issues with the cross section annotation. I have a design surface that I was able to annotate every cross section in the set. I added a design feature that was marked as not to triangulate and now only half of the cross sections will annotate. I have refreshed, retriangulated the surface and they still will not annotate. Need help in getting this resolved.
Hi Daniel,
The first thing I suggest is to ensure that your feature does in fact exist in the sections not being annotated. Also, does the elevation of your feature fall within the elevation of your cross sections range? With those items verified, if you are still not able to annotate your feature, turn off the feature and surface, close the dialog box and try to annotate again.
Sanders
Cross section not profile.
Daniel,
Do the triangles in fact exists at the location in question? The cross sections will not annotate any segments where the triangles are missing from the surface. Have you tried to display the surface line to verify that there is an active surface at that specific cross section(s)?
While segment annotation is possible, by using features, you can annotate the "apparent" segment between them and by selecting certain features and running the command multiple times, you can annotate some segments and not others. see the Vermont AOT CADD pages for their InRoads guide.
