I'm using v#08.11.07.494 on Windows Vista.
I have created a design surface which includes stripping. Since the stripping is considered unsuitable to be used as fill, I wish to calculate fill based on normal fill and the additional fill to replace stripping. I thought I would be able to do so by changing the classification of the material from "design" to "unsuitable" but doing so does not alter the volumes generated by the report.
Am I missing a setting?
Small Clarification:
I have stripping components and have set the classification to unsuitable and include in mass ordinate. What I need is stripping under fill to be included in fill section with stripping in cut included in cut section. Is there a way to do this?
is this on InRoads or Geopak
Similar question or software problem. I have overlay component to remove bituminous layers of existing pavement. now I am calculating end area volumes of earthworks. I set classification for this component to Unsuitable but when perform calculations its area is hatched with cut shape and cut area is not reduced by overlay component area.
Thanks for any input that will help to sort that out.
Inroads v8.11.07.615
Best,
Adam
OpenRoads Designer 2022 (10.12) | OpenRail Designer 2022 (10.12)
