i recently upgraded InRoads to the ref version to fix a bug that i had regarding station display with an equation station.
now when i display cross sections using a border cell the element definations are over written to default
i can insert the cell and it retains the correct definations and the existing border cells also are correct only the new cells that are being put in by InRoads
You have found a Defect that did not get caught unfil after the 615 build was released. (D-120582) So, unfortunatley, it looks like you might have to do one more upgrade.
This Defect was fixed in a Prioirty Build that we have here in the Technical Support Group. I will send you an e-mail with the link.
