Anyone from Bentley willing to help ??
I just upgraded to MS ss3 with windows 8.0 and when I did, there were SEVERAL things that stopped working, including not being able to upgrade to windows 8.1. I ended up having to do a total "RESTORE" on my computer, and then upgrading to windows 8.1 THEN loading MS ss3. Everything seems to work now. I spent about a week on this issue and Bentley was zero help, so not sure you're gonna get much more of an answer than this.
Is your Window 8 is Single Language or Window 8 Pro? I'm having few errors on displaying or selecting the .pss file, mine is Win 8 Single Language..
My post communities.bentley.com/.../92434.aspx
Best Regards,
Kugan (Account Manager & Technical Adviser on MX and ORD)
As you mention Windows 8 and 8.1 aren't supported operating systems for MX v8i SS3. For that reason I'm unable to offer install advice for Windows 8 and 8.1 operating systems issues.
Even if you manage to get the software installed and be able to create a project there can be parts of the software that don't register correctly and give errors such as the .pss issues that Kuga is seeing.
Installing on an unsupported operating system is a risky move as it may cause problems with your projects that may impact work deadlines.
The best advice I can give is to run MX on a supported operating system until such time that a version is released that supports Windows 8 and 8.1.
Gatkins94
Thx for mentionig it but your problem was related with MS SS3...and mine with MX...but I also installed MS SS3 and it worked well on both Win8 and 8.1.
