Is there a way to change the LandXML Translator Export default Linear Units to US Survey?
Jeff;
What version of the software are you using?
I am using version V08.11..07.615 on a Win7 64 bit OS
The command is supposed to read the active Master Units in the Design File and populate the units based on this setting. When stepping through the command I was able to have it change the units between Metric and Imperial but it would not distinguish between International and US Survey Foot. So I have file a change request to have this option looked at.
S-99728
Answer Verified By: Jeff Graham
Thanks for filing the CR
