Anyone has an experience with 3D Geometry Tool: Plan By 3D element?
Help says nothing about that tool under 3D Geometry. I guess it should create a 2D element with active profile in my 2D model from a selected 3D element but I can not make this tool working. I select 3D elemnt and nothing happens. When I try to use that tool again with the same element it says that it has 2D representation.
Thanks in advance.
Adam
Your description is correct. Selecting a 3d element with the tool should create a 2d element with profile from the 3d one. The is a known issue with the feature definition getting removed so check if the default level is on as it might have place the 2d element on a hidden level.
Ian
Ian,
All levels are on. No new 2D element is created and when I try to use that tool again it says that element has already a 2d representation. I can't find any new 2D element neither in in a Civil Model tab in Project Explorer nor in design model.
I tried to utilize that tool with a few different Feature Definitions with no success.
Thanks in advance,
Best,
OpenRoads Designer 2022 (10.12) | OpenRail Designer 2022 (10.12)
It is my understanding that this tool will create a 3D line string based off the civil element- plan / profile at the station range you input when creating...
The use for this would include using the resulting 3d "ruled" element in a terrain... Understand, by ruled, the new 3D graphic will update when a change is made to either the horizontal or active profile of the parent element.
HTH
Mike
Michael Barkasi
Application Engineer
Reality Modeling
Adam, I think you are right. The tool does not appear to be working correctly. Several weeks ago, I tested this command and was unable to get any results. Based on my tests, I logged defect, D-127225. In addition, I logged D-127226 which states that information on this command is omitted from the Help document.
