We have 2 surfaces with similar terrain boundary (x, y are the same). However, in computation the volume between terrains, the volume is zero in neither cut nor fill.
Any idea?
The area enclosed by the dtm's is very small (0.09sq m). In the civil report browser, if you go to the menu Tools->Format options and increase the number of decimal places for cubic units you will see a result in the volume report.
