InRoads S&S
Hello all,
In InRoads S&S is there a way to draw a pipe with several curves without placing a manhole at each change of direction? The attached screenshot should clarify what's being described. I understand that the Curve Pipe tab under Drainage > Lay Out allows a single curved pipe, but in this situation the pipe is sinuous without manhole structures at each curve. Thanks in advance.
MicroStation V8i (SELECTseries 3) - V08.11.09.459
InRoads Suite V8i (SELECTseries 3) - V08.11.09.493
