The following issue was submitted to Bentley Technical Support. This issue has been transferred to this forum so that the community can benefit from the troubleshooting techniques and resolution.
Is the Roundabout tool available for InRoads Suite ver. 8.09.02.16?
The Roundabout tool is only available in InRoads versions 08.11.05.49 through 08.11.07.615. It was removed in SS3 version 08.11.09.493 and replaced with civil cells.
is there an Add-On For the XM version or another option?
Unfortunately the Roundabout tool is part of the civil platform which is not compatible with XM. Prior to that there were no roundabout tools. Upgrading is the only solution.
I thought there was a separate download for the roundabout tool for XM.
I have the following on our install folder:
Bentley Civil Enhancements - Roundabouts.msi
Nice job, caddcop! I didn't realize this enhancement was available for XM. Learn something new every day! So, the answer is YES, you can download a roundabout tool for XM. I located it on our SelectServices website. If you set up your search criteria as shown below and click Search, you will see the "Civil Enhancements -Roundabouts for InRoads" about 3/4 of the way down the page.
