I am trying to import the FEMA 100 Yr water surface elevation from HEC-RAS to InRoads. Does anyone have any type of procedure that would allow me to do this. Thank you.
If you have a GIS or SDF file from HEC-RAS, you can use the Evaluation>Hydrology and Hydraulics>Generate Water Surface Data command in InRoads.
In the command, set the "Create" field = Water Surface, give it a name in the Water Surface "Name" field, hit Apply and browse tot he GIS or SDF file.
