InRoads V08.11.07.615
MicroStation V08.11.09.357
Windows 7 64 bit
I receive a crash every time I perform the following workflow:
This workflow is performed on the second (left) monitor. If you need a dataset, please let me know.
Andrea
*Workaround at the moment is to place the Simple component and then change the width with Point Constraints.*
Andrea,
I just reproduced the crash and will be filing a defect. I will update this post with the defect number.
Thank you for reporting this crash. I have filed a defect on your behalf. The defect number is D-129074.
Answer Verified By: Andrea Garecht
