Today I noticed to my surprise, that a clipped reference is not calculated at the component quantities. Am I doing something wrong (see attachements)?
Will there be in the next version of Open Roads an easy and accurate way (like to calculate quantities tool, if I don't use clipping references) to calculate quantities of multiple corridors, Civil Cells and terrains at once?Civil cells for example are at this moment dramatically to calculate / costs a lot of time.
Regards Louis
Example of component quantities with a clipped reference.
Example of component quantities without a clipped reference. Like you can see are the quantities the same.
This change request is still under evaluation by development and (as you know) was not implemented in the first SS3 refresh.
Hi Louis,
You can calculate the volume for each component separately, it give me the good volumes.
Regards, Christiaan
Answer Verified By: Louis van Amerongen
Hi Christiaan,
Just tested you're suggestion and it looks like you're right. In the previous version this didn't work.
I think this in combination with the table tool in the Early Acces Review of MicroStation, can be a great enhancement (replacement of the quantity tools). I only miss some calculation functions in it right now.
