<?xml version="1.0" encoding="UTF-8" ?>
<?xml-stylesheet type="text/xsl" href="https://communities.bentley.com/cfs-file/__key/system/syndication/rss.xsl" media="screen"?><rss version="2.0" xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:slash="http://purl.org/rss/1.0/modules/slash/" xmlns:wfw="http://wellformedweb.org/CommentAPI/"><channel><title>how to export Cogo points to data collector?</title><link>https://communities.bentley.com/products/road___site_design/f/geopak-inroads-mx-openroads-forum/92892/how-to-export-cogo-points-to-data-collector</link><description>How do I export cogo points to a txt file with (point name, northing, easting, elevation, code and note), so that I can use them in my data collector to stake points in the field?</description><dc:language>en-US</dc:language><generator>Telligent Community 12</generator><item><title>Re: how to export Cogo points to data collector?</title><link>https://communities.bentley.com/thread/268071?ContentTypeID=1</link><pubDate>Wed, 27 Nov 2013 20:35:42 GMT</pubDate><guid isPermaLink="false">6dad98f5-dbc9-4c4d-a9ba-e9da8dc6aa8e:af44f685-3dbc-4760-b26e-0be1cb30d012</guid><dc:creator>Sanders Thomas</dc:creator><description>&lt;p&gt;Hello,&lt;/p&gt;
&lt;p&gt;Within Inroads, you can select Geometry&amp;gt;Review Geometry Points and set your Mode to All Points and Report this will display the Report Results. &amp;nbsp;You can then select Save As and set your Save as type to *.txt.&lt;/p&gt;
&lt;p&gt;Thanks.&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item></channel></rss>
