I am using GEOPAK Drainage while in MicroStation with GEOPAK SS3 loaded. My task menus appear differently though, and I can't find some of the tasks in SS3 that I am used to seeing in SS2. How do I get all of GEOPAK Suite SS2's tasks to show up in GEOPAK SS3's Classic Civil Task menu? Specifically Drainage and Water Sewer are missing.
You will most likely need to edit the GEOPAK TaskNavigation DGNLIB file and customize it with the MicroStation>workspace>Customize tool
What happens when GEOPAK is upgraded? Will the new dgnlib automatically replace the modified dgnlib?
Yes the install process would be putting new files in. So therefore maybe create your own dgn library where you have your task navigation menu customized to access all the tools you want. Then configure Microstation within your workspace to point to that dgnlib. You may want to post technical workspace related questions to the MicroStation forum too.
