Hello all,
I've run into a situation where we are placing two inlets side-by-side in an effort to capture more runoff. Is there a way to layout a pipe so that it connects to the sides of an inlet, as opposed to the face? The attached figure should help clarify what I'm describing. I'm thinking the short length of pipe would not greatly affect computations, but want to be sure to model the network correctly. Thanks in advance.
MicroStation V8i (SELECTseries 3) - V08.11.09.459
InRoads Suite V8i (SELECTseries 3) - V08.11.09.493
