I recently watched a You Tube video on how to make horizontal and vertical geometry automatically annotate. It would be nice to be able to have cross sections auto-annotate in this same fashion (have the sections annotate at the time they are created). Does anyone know if this is possible and if so how would we go about setting it up? We are currently using Inroads SS2.
Using the command Geometry > View Geometry > Options, you can set up auto-annotation for Horizontal Elements, Vertical Elements, Closed Areas, Stationing, Curve Sets, Vertical Change in Plan, and View Horizontal & Vertical Regression Points. Unfortunately, no such option is available for Cross Sections. They must be annotated in a separate step in the Annotate Cross Section command.
