Adding Alignment Points to Cogo Buffer AND Retain Alignment Point Name
I am using MicroStation V8i (SELECTseries 2) - Version 08.11.07.443 and InRoads Survey V8i (SELECTseries 2) - Version 08.11.07.494 I am trying to add alignment points to the COGO buffer while at the same time retaining the original point names. I have tried unsuccessfully to accomplish this by using the tool located at GEOMETRY > HORIZONTAL CURVE SET > EVENTS. I have also tried unsuccessfully to use the ASSIGN NAMES tool. Using the events tool, I have no problem creating COGO points with NEW point numbers, but I need to use the existing alignment point numbers. Thank you all for your help.
