Hi, I have installed microstation SS3 (.459) but i couldn'y find any civil accudraw and civil geometry tools in it. I have uninstalled and reinstalled a number of times but still with no success. The setup is correct as the same tools could be found in my colleage machine. I have tried with both versions of SS3.
A word of warning: The command line switch solution will only work in the very first release of SS3. In the recently released refresh (08.11.09.674) this is no longer an option. Please refer to the following article for more information:
communities.bentley.com/.../12618.enabledisable-civil-products-from-within-microstation.aspx
So... How do we specify whether to run GEOPAK SS2 vs. GEOPAK SS3? Am I misunderstanding you? We presently have two different shortcuts that either use -wsLoad_GEOPAK_SS2=1 or -wsLoad_GEOPAK_SS3=1 along with pointing to different workspaces.
Let me clarify, you can still use the two different shortcuts. The difference is that GEOPAK SS3 is going automatically activate when you launch MicroStation.
