Power Inroads - SS2 - Surface - Delete Features
A user has brought to my attention that when attempting to Delete a group of features from a fairly large .DTM the command seems to require a large chunk of time, he has waited in excess of 10 minutes apparently with no results.  The .DTM in question is around 19mb, and he is using PowerInroads 08.11.07.615 for his surface edits.  Using a fence, and feature filter to narrow down his results also appears to produce no better.
My question is, does this command just take this long?  I know there could be a million variables here, however was hoping someone recognizes the problem as something simple =)  I was not sure if perhaps after the delete command finishes, that the entire file is attempting to re-display or something like that?  Any help is appreciated, thanks!
