Create Profile By Constant Elevation doesn't work when you put a minus value in to it (Elevation: - 0,50) it jumps back to 0.50.
Is there for an work a round? Otherwise I have to check every single line in the profile model and that's to much work.
Thanks in advance
CP
What product and what version are you using?
PowerCivil V8i SS3 08.11.09.495
Let me look into this a little more but I was able to reproduce the problem.
As a workaround, I was able to set the elevation to a positive value to initially create it, then open a Profile View of that element and adjust the constant elevation profile. Select the vertical and in the Element Information you can set the 'Profile Line Between Points Rule' elevation value to the negative value and it reflect that negative elevation.
I found an existing forum question regarding this issue. It appears that there is a bug and a defect has been filed for this issue. D-125902 has been filed for this issue.
communities.bentley.com/.../90085.aspx
Thanks, I looked over it.
The work around is a hell of a job when you have a lot of elements.
Christaan:
You should be able to ease the workaround a bit by editing the profile value in element information instead of opening a profile view. Just select the plan view element, then open element information. The profile rule should be visible in EI along with the horizontal rule values. This is still unhandy, but a little bit easier than actually opening a profile view.
Robert GarrettSenior Product EngineerBentley Systems Inc.
