When selecting elements and holding left mouse key some kind of context menu pops up. Is it possible to adjust or disable it?
If you wish to disable the context menu, in MicroStation, go to Settings > Snaps > AccuSnap. On the General tab, toggle off Pop-up Info.
Answer Verified By: Oto
this is a terrible solution as checking this box off also completely disables this super useful menu.in red i have circled the menu that most people absolutely despise.in green i have circled the menu everyone loves because it provides information about the hovered element without literally stopping you from pressing the delete key or starting another command with the keyboard.
i want to be able to turn off only , ONLY, the menu circled in red without disabling the menu in green.the red one:
- stops delete key until you move your mouse away
- stops you from starting other commands like move or copy
- stops you from using your clipboard.
- basically just hinders your ability to use ORD as you normally would
the green one:
- awesome
- just shows information
- doesn't get in the way of commands or key presses
- vanishes quickly if you want it to.
i'm absolutely peeved that these menus still don't have different buttons/checkboxes/pulldowns settings to control them.
sometimes i DO want the red menu, but when i don't its absolutely frustrating.
also changing the delay isn't super helpful because that also changes the delay of the green menu.
anyway, thank you for responding anyway. several people in various forum posts keep complaining about this and i'm surprised both menus are still controlled from one box several releases later.
