How to Automatically get offset/elevations on fixed points on a cross-section? How to export these offset/elevations to Excel?
Hello
I am running Microstation V8i.
I need to get offset and elevations of a particular set of points on a cross-section. Is there a way to get these elevations if I fix the offset to increase by X feet after every DP? In other words; if I fix the offset; can I get the elevations of these points by automatically using Geopak?
Also, is there a way that I can export the offset/elevation that I get for these points into Excel?
Thank you.
