I have tested different SRL tables and I'm unable to calculate superelevation for my ramp alignment. My alignment was designed by element method (don't have such problem with complex elements created by PI method) and consist of: ARC from element with back transition - SPIRAL - SPIRAL - ARC from element with back transition - LINE
Does anyone has similar problem?
Regards, Krzysztof
Can you post up a DGN with a geometry alignment as you have described? Even though it may not work with any SRL tables, can you provide a workflow of the steps you are using when assigning the SRL so we can step through and test it?
I sent you DGN via email. My workflow is as shown on the video attached. Thanks.
This issue was reproduced at my end. The defect has been filed for it in TFS.
The defect ID is 75439.
Answer Verified By: Krzysztof Burdziel
