Nodes With No Width
Generating stormwater conveyance system profiles. We set up a custom drainage library, created and analyzed a network. When generating a profile of the network the nodes are shown as single lines. I haven't been able to determine where I need to define the width of the node or structure besides the grate information in the drainage library. Do the new structures/nodes require custom criteria files? If so, any suggestions (not in Bentley Institute) on criteria basics and setup? Matt
