Good morning all,
I am having an issue with GPK drawing my surfaces that I produced from Roadway Designer. When I am in RD, I can flip through the stations and the existing surface and proposed surfaces and information look good. I will then use the Create Surface tool within Roadway Designer and create the proposed DTM file while also displaying the features and components. When I look at the 3D features and components that are created, everything looks good and it covers the full limits of my project. When I go to the Draw Cross Sections from Surfaces tool within Corridor Modeler, I setup both my existing DTM and my new proposed DTM to be drawn. Once it draws these two surfaces, the existing surface is drawn through the end of the project, but the proposed doesn't show up on the last 4 or 5 sections. Any idea why this would be happening?
Thanks,Ken
Kevin,
I installed the priority build and then recreated the DTMs, but it is still doing the same thing. I can see that the features and components are displayed properly in the course of creating surfaces, but when I try to cut the sections from the new DTM, it doesn't cut anything after 93+50. Any other ideas?
OK... sounds like we need to do some troubleshooting offline. I've sent you an e-mail.
FYI for anyone coming across this post later. We did a clean uninstall/install of the Priority Build and then were able to verify that it did resolve the issue.
