InRoads - List of Roadway Designer Stations?
Hello, Is there a way to list (or edit the list of) the stations that the Roadway Designer has for each corridor?  Going through design, you may enter an odd station for a cross-drain or look at an event point for an intersection that later gets moved, etc.  Later in the design when you are looking through the sections, every one of these stations you ever looked appears to be included.  On a long alignment that has had multiple iterations, etc. this leads to a lot of excess/unnecessary stations in the list.  How can I see or edit the list of stations that the corridor displays in the Roadway Designer?  I'm a new InRoads user so please be as detailed as possible in any response.
Thanks for your time and assistance.
Edit: Using InRoads Suite V8i SS2
