In the attached file the manipulators for the left profile will not display when the profile is selected. The manipulators will appear when the right profile is selected. Vertical Alignment reports can be produced from both profiles. What am I doing wrong?
Thanks.
mh
SS3g 08.11.09.493
I am testing your file, I am working on it.
Thanks Ricardo,
This geometry was imported from a GPK file. While working with the import again the notice "Profile 'SR76_PGLLT' is too complex for civil rule creation." appeared in the message center. On a hunch the vertical curve for VPI #3 was shortened to 379.00 feet in the GPK file to remove the PVCC at station 2304+50.00.
The SR76_PGLLT profile was imported into a new file and now correctly displays the manipulator handles.
This looks like a bug to me, the original GPK file is attached if you wish to verify this.
Answer Verified By: MikeHarvison
job076.gpk
Hi Mike ,
The profiles was creating using differents tools, the profile PROP_PGLLT was create using MS tool COMPLEX CHAIN, and the profile PROP_PGLLRT was creayed using Geometry tools, you can see the icon in the left side of the profile name, they are different, that is the reason the profile PROP_PGLLT does not work.
Ricardo,
Your response does not explain anything. Please see my post from March 4th .
Mike
What I try to explain you is that profile PROP_PGLLT was create using Microstation's tools COMPLEX CHAIN, the elements of this chain has not intelligent, it needs to store using "store graphics" tool from Geopak and then it will be store in the gpk in order to import the GPK from OpenRoads, and then the profile will work fine as the other one (PROP_PGLRT)
