Good Day Geopak World,
Last week, my GEOPAK Project Manager box all of a sudden disappeared. It is not hidden in the Windows Task Bar, and i have tried to go to Applications - Geopak - Road - Project Manager as an attempt to "backdoor" into it. Nothing has worked. I have tried to reboot, etc.
I can still use all other GEOPAK elements - D&C Manager, COGO, XSN Navigator, DTM visualization tools, etc - but i cannot get the project manager box up. Therefore, i am stuck in the current project and working alignment.
I have been working with GEOPAK for 7 years so i am quite familiar with its quirkiness. Has anybody else encountered anything like this?
ok. don't panic... try this
Delete everything under the 8.11 folder
On Vista the location is
C:\Users\yourusername\AppData\Local\Bentley\MicroStation\8.11\
On win 7
C:\Users\ yourusername \AppData\Local\Bentley\MicroStation\8.11
on WinXP
C:\Documents and Settings\ yourusername \Local Settings\Application Data\Bentley\MicroStation\8.11\
I've found the folder, but i am hesitant to delete anything. Is there something I should replace it with?
I am afraid you may need to uninstall geopak and reinstall
I uninstalled and reinstalled...still no luck. In the "Message Center" on the bottom of the screen it gives the Message "GEOPAK IS NOT LOADED" whenever i try to open the proejct manager. I can still use COGO, etc.
Any advice?
I suspect that you are running Geopak Site and not Geopak Suite. can you copy and paste the name of the install file you ran?
gkste081107536en.exe
then
gkste081107566en_updt1.exe
ok that is the correct one. not the latest but correct. if you can send me your email address and your phone number, we could do a teamviewer and I can look at your machine and see what is going on
Answer Verified By: Nico Roman
