I am working on setting up a template that has guardrail, but I want to be able to display the guardrail component only when there is an associated plan view graphic found for that side at a given station. The old way I was doing it was to have the conditional expression saying that whenever the shoulder widened to a certain width, to then display the component. This doesn't feel very intuitive and not a very accurate. I thought there was a way to display (on/off) components based off plan graphics as well as drawing the component to the associated offset of that plan graphic.
Geopak SS2
Thanks for any help,Ken
One possible solution would be to create a null point and assign the null point a style constraint of the imported plan graphic. You can apply the display rule to that based on your width requirement too.
Beebe,
Thanks for the reply, but I am not sure I understand how it works. I am still new to template creation and I have never played with the Style Constraints. I looked in help, but couldn't get much from it. The image below shows my current GR template which has a null point (GR Origin). I have set this point to use a Style Constrain which will be the same style when I bring in the GR element in my plan view graphics. I suppose I don't understand how to get from here to only showing this component (in the full template) when that plan view graphic is at that station.
Anywhere I can look for this information?
So maybe you can create an end condition that seeks the StyleXY or FeatureXY instead of a Surface. Choose the feature or style and then set the point of the end condition to do not construct. Then set the Guardrail Feature to be a child of the end condition that only solves when it finds the Style or Feature.
Thanks for the suggestion Beebe. This makes sense and I will let you if I have any further troubles.
