Is it possible to rename a linear template after it is defined in the design file? I have tried in both the properties menu and the project explorer. In both cases, when I go back to the template definition, the name reverts back to the default name created when placing.
Marc
Inroads SS3 674
Does anyone from Bentley have an answer to this?
If you right click on the Linear Template and select the quick properties dialog it seems you should be able to change the name, it appears to let you even so far as to not allow you to edit the name to one that already exist. This linear template function appears to be very similar to a Corridor definition and the corridor can be renamed from the properties dialog.
Mike LongstreetVermont Agency of TransportationCivil Engineering Technical SupportVTCAD Help
Hi Marc,
You should be able to rename as Mike mentions above, once changed, right click on your Linear Template and Process Corridor, you should then see the name change.
Thanks!
I am not getting these same results. I follow those steps but when I check the name again it reverts back to the original name.
Does anyone from Bentley have an answer to this??
