Looking for the Create Template functionality that allowed for the import of MicroStation Graphics to create a Template. I have in the past used this many time to create complex templates of objects that are already drawn in MicroStation graphics. One good example is a Bridge Deck Template. I usually get if from the drafted typical sections and import it into a template to create a roadway modeler model of the bridge. In InRoads SS2 it was under the create template File > Import menu.
I logged CR to have the option to import template from graphic a while ago.
As a workaround you can use InRoads SS2 to import templates from graphic and then you can copy templates between itl files.
Answer Verified By: Mike Longstreet
Yes I did use SS2 to import the template. Was the CR as a first SS3 release, did you here if there we plans to make this work again?
Mike LongstreetVermont Agency of TransportationCivil Engineering Technical SupportVTCAD Help
