If I hase used a feature definition defined from a library a copy of this feature definition is placed in the design file. If the feature definition is then updated in the dgnlib how can this same feature be updated in the dgn file?
You will need to redefine the feature with the revised feature definition. The easiest way to do this is to change the feature definition to a different one, and then change it back to the desired one. In the current version, the changes made to the feature definition are not automatically updated in the DGN.
Has this feature now been added to ORD?
Chris
AECOM Roads UK&I Digital Engineering, Design & Solutions Lead | Sector Information Management Lead
Associate Director – Digital
OpenRoads Designer 10.11 | MicroStation CE 10.17 | ProjectWise CE 3.4 | ContextCapture | ProjectWise PowerShell 2.0 | Generative Components | OpenBridge Designer 10.11
Revit 2022 | Civil 3D 2022 | Recap 2022 | Infraworks 2022 | Dynamo | Navisworks Manage
PowerShell | Visual Studio | Office 365 | Power Automate | Teams | SharePoint | Visio
Speckle | BIMVision | Revizto | Solibri
any news? That feature would be very useful.
Josef
Very urgently needed!
Mark
OpenRoads Designer 2022 R1 (10.11) | Microstation CE Update 17.2 | ProjectWise CE 3.4
