Corridor modeler ddb
Corridor Modeler - PowerGeopak SS2. (yep.  we have SS3 but I still need to set up some standards for SS2 as well)
How does an administrator begin to revise(or better yet create a new) corridor modeler ddb file.  I located the original Bentley ddb and noticed there was a corresponding dgnlib (default_styles.ddb and default_styles.dgnlib).  The dates, however are not the same as I would expect if you could update the dgnlib then the ddb automatically updates.   I have also read a number of threads talking about the xin to ddb conversions.
How do you start with a blank ddb or better yet start with some other nice clean empty file, and then convert to a new ddb.  Perhaps the preferred method is to copy the ddb and dgnlib to your config path location(or keep in the original install location) and revise the ddb.  How do you revise the ddb?
Appreciative of any suggestions.
Thanks all.
