We work in both Microstation V8 and PowerCivil. Within Microstation there is a command that will set an element to an elevation, and then increment up or down to a new elevation. This command is very useful when setting contours to the correct eleveation. The command will not work in Powerstation, is there a command that will set an element to an elevation and then increment to a new elevation?
I have used Civil Accudraw for this with the move command
Joe Lukovits
User Since TDP in the 80's,
Vax based Unix Workstations - Interpro32,
from the Intergraph Corp.
