Hi
Where can I find video which show how to create pond and volume calculate in InRoads ss3.
I have PowerCivil for Denmark ss3
Thanks in advance
Sigfús
Are you using the OpenRoads tools to create the pond?.
I don't have a video for the pond creation in OpenRoads but the workflow below should help you.
Thanks Jason, I try this :-)
Let me suggest a slight change in the suggested workflow which might be useful.
The advantage here is that since the top and bottom surface are defined by a 3D volume rule you always know what the storgae volume is and if somehting changes, you can redesign the pond by simply selecting the 3D Volume element and change the property for volume larger or smaller and the entire pond design will update.
Robert GarrettSenior Product EngineerBentley Systems Inc.
Answer Verified By: Sigfus Jonsson
Thanks Robert :-)
..now I need a help with this one...volume calculation of the cut and fill of earthwork for this pond :-)
