Using inroads to calculate volume
I'm pretty sure I've done this before and I simply cannot remember the sequence of doing so.  I have a base topo and am overlaying a final fill plan.  Wanting to calculate the remaining fill, normally I'll calculate the area of each  5' contour in sq.ft using a planimeter.  I take average between each contour and get a cu.ft. then cu.yd. if needed.
Can't this be done in InRoads by importing these shape surfaces for each contour?  What are the steps?  I am drawing a blank...or I'm mistaken and I've not done this in InRoads.
Thx for your help.
