Create Terrain By Text Interpolation
My client has given me a 2D dwg file and I need to convert to 3D.
I found the following link
http://communities.bentley.com/products/road___site_design/w/road_and_site_design__wiki/9881.aspx
but following the video the explanations I have not got the expected result.
I need to triangulate the points with the text´s elevation, and I need to get 3D points and 3D lines, not only 3D points.
Can anyone help me?
The 2D dwg file contains Acad Proxy Entities.
Using the command "Drop elements" I have separated the elements but the yellow spot becomes two String lines.
Can I make it a spot?
Thanks.
PRUEBA.dwg
Parents Reply Children
