I use jpegs attached thru the raster dialog box for our site location maps and they do not print from the print organizer if I have inroads open. I have to close inroads open MS and then they will print.
using MS Ver. 08.11.09.459
inroads ver. 08.11.07.615
but have been having this issue for a few years, so ther version of MS and inroads does not matter.
Bryan
As a test, please try removing the file msgeo.cfg from the following directory:
C:\Program Files (x86)\Bentley\MicroStation V8i (SELECTseries)\MicroStation\config\appl
Please move this file to a temporary location, relaunch InRoads, and test to see if the problem is resolved.
Answer Verified By: Bryan Greisch
That worked, is there a way to disable that msgeo.cfg without moving it on all the computers, especially most people do not have admin rights to move it.
